cooling temp sencer
Old Jun 19, 2010 | 08:03 AM
wildracer's Avatar
cooling temp sencer
i have a 97z28 fully stock and it through out a code for the coolent temp sencer if i pull that sencer out will coolent come out as well???
Old Jun 19, 2010 | 08:11 AM
1994formy's Avatar
Yes.... It'll come out of either sensor when pulled.
Just be ready with your new one in one hand when you have the old one nearly threaded out, and you shouldn't lose much.
Old Jun 19, 2010 | 08:54 AM
Be VERY CAREFUL when removing the coolant temperature sensor from the water pump housing. Coolant will definitely come out of the hole when the sensor is removed, and you do NOT want to get that coolant on the Optispark distributor, or your next post will be "why is my car running like crap?". Put a rag over the Opti before you start work.
Old Jun 21, 2010 | 06:37 AM
wildracer's Avatar
thanks guys for all the help THIS SITE ROCKS!!!!!!
jerrysims71
Aug 15, 2015 12:47 PM
4586
Aug 13, 2015 10:11 PM
Aug 7, 2015 01:26 PM
4586
Aug 2, 2015 01:45 PM
Noct
Jul 14, 2015 01:18 AM
