Cooling system help needed!
Old Mar 18, 2005 | 10:08 PM
  #16
phinger23's Avatar
Re: Cooling system help needed!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
thanks all, well i spent about close to 8 hours under my car today because it wouldnt start. come to find it was a corroded battery connection, i ended up removing the battery, alternator and belt and had them tested (brand new alt. too..4 days old!!). thats ok tho, i changed the belt, the coolant, a few hoses, changed the oil, cleaned some stuff up, changed the coolant level sensor which was bad (50 effin dollars!!), and a K&N air filter.
car is a 95, AC has no refrigerant which is why it dont work.
Old Mar 19, 2005 | 01:10 AM
  #17
Bawls's Avatar
Could have just unplugged it.
Old Mar 19, 2005 | 01:32 AM
  #18
ManicHaze's Avatar
glad you got your cooling issue worked out. I had one not too far back, when i removed the intake elbow to put in my 160 thermostat the damn silencer tube broke the connector on my coolant temp sensor. It made the car really hard to start. So word of warning, be careful removing the intake elbow hehe. (I went to one of the 1LE elbows without the silencer tube)
Old Mar 19, 2005 | 07:33 PM
  #19
Evilfrog's Avatar
Originally Posted by 1stz28
That is the condenser.
I dont care what it's called. Clean it out.
Old Mar 19, 2005 | 10:49 PM
  #20
phinger23's Avatar
no way, i was sick of seeing that light on the dash, besides, its a good light to have anyways.
Old Mar 20, 2005 | 04:59 AM
  #21
Bawls's Avatar
Unplugging it, causes the light to go out. It's only a good light to have if you're too lazy to check your radiator every now and then. LS1's dont even have them.
Old Mar 20, 2005 | 10:22 AM
  #22
MarineReconZ28's Avatar
Why did the sensor cause the car to be hard to start?? My car has started right up as long as I've had it, but after I installed my single 3" bullet muffler it has been acting up. And I did have the elbow off the car for a while. I'll have to check that.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
mjcent922
Jul 27, 2002 12:42 PM
