Cooling system
Old Sep 24, 2005 | 04:33 PM
LiENUS's Avatar
Cooling system
Well i was driving and my car tried to overheat on me, managed to kill it before it did and got it home pulled the intake off andnoticed that the hose with the bleeder valve on it had a hole in it (not the one coming off the t-stat housing, the other one), I suspect my radiator may be bad as well. For this hose, how much will it cost if i get an acdelco replacement? and where does that hose end? Hopefully my radiator aint bad but i got a mechanic coming to take a look and see if i should take it out and replace it. while im at it i plan to replace all the radiator hoses, hose clamps, and the water pump and if I need to, replace the radiator as well.
Old Sep 25, 2005 | 04:14 PM
LiENUS's Avatar
Re: Cooling system
Pulled radiator out, neither tank looks cracked so it may be ok, gonna have it inspected looks like was just bad radiator hoses on it, the hose that was busted was the heater hose, both hoses need replacing. everythings unbolted and loose all i gotta do is get new parts and put em in.
Magenta_Hearts
Mar 25, 2015 10:24 AM
grgguy
17
Feb 23, 2015 07:57 PM
kksi
Feb 17, 2015 10:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
