Cooling problem help
Old May 22, 2006 | 06:46 PM
firefighter's Avatar
Ok so i just replaced the water pump and despite wanting too i didnt just set the car on fire. But the car is still getting hot. right after i replaced the pump i took it out and ran it hard for about 20-30 mins to get the temp up. it never got above 1/4 on the gauge. but today i go and drive it and out of nowhere the temp shoots up. then when im gonna pull over to let it cool off and check on it, the temp goes back down to normal it did this 3 or 4 times before it finally over heated. any help would be great.
Old May 22, 2006 | 07:06 PM
Demus's Avatar
Re: Cooling problem help
Did you verify that the coolant fans are working correctly?
Old May 22, 2006 | 07:09 PM
just messed with it they are inttermitent. just the fans not working will cause it to over heat that bad?
Old May 22, 2006 | 07:46 PM
Demus's Avatar
Yup.
Old May 22, 2006 | 08:15 PM
Joe B's Avatar
Here's a few things to also check..... make sure you have every bit of air blead from the system by getting a steady stream of water comming from the bleed screws.......and (if you want) putting the fans on a 2 dollar manual overide switch right at the solenoid can help greatly as well("reguardless" of what temp the computer is programed for them to come on at).....and you can also try running a little higher mixture of water, since water cools much better than antifreeze.....you can also boil the thermostat to verify it's opening fully, "and" at the right temp.....
Old May 22, 2006 | 08:22 PM
is there any way to get better air flow to the radiator in the 93-97 camaros? also whats the best way to hook up a fan override? just jump the wires off the coolent temp sensor ?
BigWil
Mar 29, 2015 12:24 PM
Lt4Z2897
Mar 26, 2015 03:02 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
