Cooling fans only go on with A/C??
Old Aug 11, 2003 | 05:52 AM
meangreen94z's Avatar
on my cousins '95 T/A, the cooling fans will only work if the A/C is on. If you shut it off, they wont turn on at the certain temp. Also, the low coolant light is on but it is full (if that matters). Thanks.
Old Aug 11, 2003 | 05:57 AM
predator's Avatar
could be a relay issue or the temp sending unit but only one fan is supposed to come on with the A?C the secondary if both come on then there may be other problems
Old Aug 11, 2003 | 08:40 AM
It may or may not have a real problem. You might want to read some background info on how the system works.
There is a current thread about the low coolant sensor and many more can be found with a search. Has the coolant actually been checked to see if it is low? An easy way to check what is in the radiator is to open the cap first thing in the morning when the engine is completely cool. The coolant should be at or very near the top.
warmeck
Jun 5, 2015 05:19 PM
timmy39120
May 8, 2015 11:41 AM
LingenfelterZ28
Apr 25, 2015 10:24 PM
LingenfelterZ28
Apr 24, 2015 02:00 PM
Biggiebound
Apr 23, 2015 08:50 AM
