Cooling fan temp
Old Mar 30, 2004 | 08:42 PM
Bobsep84's Avatar
Cooling fan temp
i am having a strange problem with my car. For some reason my radiator fan does not turn on till 240 degrees! i have a 180 deg thermostat so as long as im moving the temp is fine, but if i idle...it will keep getting hotter and hotter and no fan till like 240. i replaced the coolent temp sencer with no luck. is my computer set to turn them on to high or is there something else? i need to fix this before summer!
Old Mar 30, 2004 | 08:44 PM
Red96Lt1's Avatar
Yeah that's normal. I freeked out too when I first noticed that. The only way to change it is to get a tune and they can change that. Or you could do a fan switch.
Old Mar 30, 2004 | 08:56 PM
Bobsep84's Avatar
Yea, that is really weird cause OEM temp is 180 thermo and thats what i got in there....thats really werid that it waits sooooo long to turn the fans on. the it gets real close to that red mark. thanks for lettin me know thats normal
Old Mar 30, 2004 | 09:07 PM
The only way to really know what the PCM is seeing as the temp is with a scan tool. It is also possible that your temp gauge is the one that is reading higher than it actually is.
Old Mar 30, 2004 | 09:25 PM
Bobsep84's Avatar
Do you guys know what the OEM fan turn on temp is?
Old Mar 30, 2004 | 09:45 PM
The pcm will command low speed fans "ON" at 226º and "OFF" at 221º and high speed fans "ON" at 235º and "OFF" at 230º.
Old Mar 30, 2004 | 10:55 PM
bluezed28's Avatar
It's likely that you have air in your cooling system. The presence of air will cause your themostat to open late or not at all, thereby causing your engine to overheat.
When you car is moving you're forcing the coolant through the system since the water pump is working harder, but at idle the coolant recirculates at a slower rate thus overheating.
I'd try bleeding the air, this is the cheapest solution (free) and most likely problem.
Wallace
Old Apr 7, 2004 | 11:44 PM
Bobsep84's Avatar
Yea, i bleaded the system of air already. the problem isn't there...the problem is the radiator fan not turning on when the engine reaches a certain temp. i have no idea what could cause this. by the way, turning on the A/C does turn on the fan like its suppost to
timmy39120
May 8, 2015 11:41 AM
LingenfelterZ28
Apr 25, 2015 10:24 PM
LingenfelterZ28
Apr 24, 2015 02:00 PM
Biggiebound
Apr 23, 2015 08:50 AM
grabbem88
Apr 16, 2015 06:57 PM
