Cooling fan only comes on when ac is on
Are you sure the coolant temp gauge is accurate? Check the sensor in the driver's side head using Shoebox's writeup. If you have access to a scanner, check the coolant temp that the PCM is seeing from the cooloant temp sensor in the water pump.
You also need to check the fan relays. All LT1's have the stock programming at 226*F for the low speed fans to come on (mid-94-97) or the first fan to come on (93-early-94), and 235*F for the high speed (or second fan).
Shoebox also has the wiring diagram - C60 is AC, use the lower "late production":
http://shbox.com/1/1995_pcm6.jpg
Noct
Jul 14, 2015 01:18 AM
