Cooler Engine?
Old Nov 15, 2003 | 01:22 AM
Heatmaker's Avatar
Advanced Member
Cool Cooler Engine?
Are there any tricks to making your engine run cooler? My car used to run around 180 degrees all year round...Even in summer heat...then I lowered her and added some Aero enhancers. Now she is cooking herself. The car stays around the 200 range then the fans come on and she cools down between 200 and Redline I took the car to the dealer so they could scan her with the Tech 2. I thought maybe the fans had malfunctioned, but they were working properly. Then the guy told me about the car not breathing well from my newly added appearance package. The cars still running hotter than usual, and I don't want to look like nascar with Ducks swarming up into the engine bay. Is there a way to cool the engine off better? Would an Meizere or CSI water pump help? 160 thermo? I've only got about $150.00 to bang
Old Nov 15, 2003 | 07:08 AM
Camaro_Maniac63's Avatar
Get a 160* thermostat, and a manual fan switch. Those should help it.
Old Nov 15, 2003 | 07:27 AM
anaik's Avatar
I believe you need a longer air deflector with the appearance package. Don't know who sells one. Try posting in the appearance forum.
Old Nov 15, 2003 | 09:07 AM
Heatmaker's Avatar
Advanced Member
I had one, but the car is so low it scrapped the ground...car became more like a Plow or something.
Old Nov 15, 2003 | 10:17 AM
TMDZ28's Avatar
get a 160* stats, and get some one reprogram your fans. set it to turn on at 180*. that should do the trick mate
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Dec 12, 2014 10:51 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
