coolent leak toward the back of the engine??
Old Oct 28, 2004 | 08:59 AM
F(ast)-body's Avatar
at the track last night and noticed a coolent smell....popped the hood and couldn't see anything around the radiator but when I looked under the car I could see water dripping down toward the back of the engine. Other than the coolent line running from the back of the heads I can't imagine what else could be leaking back there.....opinions?
Old Oct 28, 2004 | 09:12 AM
LilJayV10's Avatar
Re: coolent leak toward the back of the engine??
Besides an intake gasket leaking, i'd say its probably the crossover tube.
Old Oct 28, 2004 | 09:20 AM
it just strikes me as odd though. The aftermarket heads have been on the car for two years now and then out of the blue the crossover tube starts leaking? Think it just worked itself lose or possibly the o ring failed? It's been so long since I put the heads on the car I can't even remember if there was an o ring....
Old Oct 28, 2004 | 09:24 AM
triumph's Avatar
You could rule out the Intake as the only coolant that passes thru an LT1 intake is in the throttle body and that is in the front. The cross over tube would be where i would start , then heater hoses and finally the head gaskets.The best way to find it is to preasure test it with a cooling system preasure tester. Steven
Old Oct 28, 2004 | 09:25 AM
InsuranceGuy's Avatar
Could be the o-rings on your oil cooler leaking. The cooler
bolts between the block and your oil filter on the rear
drivers side.
Emil Dusek:93Z
Old Oct 28, 2004 | 09:29 AM
WS Sick's Avatar
Either the Crossover tube or a head bolt. (at the back)
calaban
May 18, 2020 06:43 PM
PCLZ28
Dec 24, 2015 05:19 PM
artic94
Jan 17, 2015 11:19 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
blac94Z
Nov 28, 2014 01:53 PM
