coolent fans
Old Jun 3, 2010 | 02:16 PM
Kalgash's Avatar
coolent fans
I need a little help please. my son was deployed and had his 1995 Z28 Camaro sent up to us. he will be comming home soon so he wanted me to get hs car ready.
when i let it run it gets hot and the fans wont kick on. i replaced the thermstat,fuse,and all 3 fan relays. and still the same. I also pulled the air pump relay and tried turning on the ac and they still didn't come on. any help would be great.
Old Jun 3, 2010 | 02:27 PM
Bails098's Avatar
you can get a switch to put on them and turn them on whenever you need.
Old Jun 3, 2010 | 02:29 PM
SnakeOiler's Avatar
how hot do you let it get? the factory setting is 226* for fan 1
Old Jun 3, 2010 | 02:58 PM
Kalgash's Avatar
wanted to make sure so let it get just about to the red lines on the guage which i belive was 280
Old Jun 3, 2010 | 03:29 PM
Look here for some help. The a/c system must be working for the fans to come on when it is turned on.
Old Jun 3, 2010 | 06:34 PM
chrisblanton's Avatar
you could also straight wire them to the fuse block and run them all the time
Old Jun 3, 2010 | 06:41 PM
It's really a waste to have them on all the time. It's not necessary, wastes HP in generating the power for them and wears the fans out sooner. IMHO, there is no upside to doing that.
Old Jun 3, 2010 | 10:57 PM
CstIrnFst's Avatar
Are you sure both fans are functioning to begin with? You never mentioned the fans turning on for any situation. The first thing would be to test the fans to make sure they are still good.
Old Jun 3, 2010 | 11:18 PM
The fuses are for the signal voltage to the relays. There is also a fusible link in the main 12V power supply to the load side of the relays. The link attaches to the red plastic "+" box on the passenger side inner fender.
Look at Shoebox's wiring diagrams.
Old Jun 4, 2010 | 07:40 PM
Kalgash's Avatar
first off thank you all for the help. sorry for not getting back sooner but work calls sometimes. so i jumpered the 5 and 6 on the DLC and the fans came on.
so now i will try and break down the wiring and see what I can find.
Old Jun 4, 2010 | 09:52 PM
If they come on when you jump the DLC, then the wiring and relays are all good. As described on my website, a scanner will allow you to read the temperature the PCM sees. It will also tell you if the fans are commanded on at the programmed temperature.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
Pwilson59
Sep 3, 2015 08:47 PM
4586
Aug 24, 2015 11:04 PM
