Coolant from throttle body?
Old Jun 3, 2013 | 09:19 PM
Greg88's Avatar
Hey guys, got everything hooked up, running good, then saw a solid stream of coolant from which looked like behind the TB? I took it all apart again, was thinking maybe the gasket under the throttle body there. It's a aftermarket one TB, not to sure exact brand but would that gasket be the same as stock?? Anyone else had this issue? Thanks!
Old Jun 3, 2013 | 10:05 PM
twistedbowtie's Avatar
Re: Coolant from throttle body?
Coolant does run through the throttle body. Some people do a throttle body coolant bypass is you search it there are a ton of write ups and then your throttle body coolant issue will be fixed.
Old Jun 3, 2013 | 11:18 PM
slick1hunting's Avatar
I would also do the bypass. Its been a while since have seen a stock tb but thought it went through sealed passage one side to the other
Posted from Camaroz28.com App for Android
Old Jun 4, 2013 | 05:16 AM
The coolant flows through passages in the plate that holds the IAC motor on the bottom of the throttle body. That plate has a gasket and multiple screws to attach it to the throttle body. If the screws are loose, it will leak coolant. I've seen people get the different length screws mixed up, and if you put a long screw in a short hole you can't tighten it.
Old Jun 4, 2013 | 06:02 AM
Greg88's Avatar
Ok seems pretty simple. Just removing both hoses from the tB and connectin them together? Simple. Now livin in Canada, as I do, but I do not drive the car in the winter, is this still ok to do? Fred, I did take it apart and noticed only two torx screws under the TB, but what seemed like alot more holes to put screws into? Maybe that is the issues, and a bypass is needed.
Old Jun 4, 2013 | 07:20 AM
No one has ever reported an issue with the TB bypass that I know of. That includes people in Canada. Its purpose is to keep the throttle blades from icing during extended driving in extreme cold. Just a base GM had to cover when marketing to the masses.
Old Jun 4, 2013 | 07:39 AM
Greg88's Avatar
Awesome thanks! What size are the hoses so I can get a connector to piece then together?
Old Jun 4, 2013 | 07:56 AM
3/8"
Old Jun 4, 2013 | 11:13 AM
You need no connector or anything else if you have a 95 or later.
http://shbox.com/1/tb_bypass.jpg
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
captcorvette
Mar 7, 2015 12:37 PM
