Moving oil pressure sender to back of intake>>
Old Mar 29, 2007 | 08:11 PM
mattbailey's Avatar
My old motor is out of the car and the sender is located right above the oil filter. My question is is there enough harness to relocate it to the back of the intake for my new motor like on 95's and up? What else would I need?
Old Mar 29, 2007 | 08:16 PM
Dave89IROC's Avatar
well, you would need to angle adapter that was used on the cars that came with it(it also changes the size of the thread, so the same sensor is used), and if the wires don't reach, extend them, but I think if you open the harness up, there will be plenty of wire
Old Mar 29, 2007 | 08:27 PM
Mike96z's Avatar
I say keep it where it is, its so hard to get to behind the intake and you will break them all the time. Unless theres a prob with it by the filter.
Old Mar 29, 2007 | 11:24 PM
SS RRR's Avatar
How?
Old Mar 29, 2007 | 11:34 PM
neversummer's Avatar
Originally Posted by SS RRR
How?
On my 93 at least, EGR makes everything tight back there. My engine builder left that hole open. So when I first primed up my engine, "Old Faithful" was in the back of my engine bay! Anyway pluggin that hole was freakin difficult with the EGR on. I can't imagine trying to fit the oil press sensor there.
Old Mar 30, 2007 | 12:25 AM
Mike96z's Avatar
HOW!!!!!!!!! The damn thing damn near touches the firewall and will break if you push it the wrong way, always see them break and from personal experience, no matter where it is really because its metal glued to plastic. Id love for mine to be by the filter, much easier, trust me dude, if your gonna put a new engine or something, dont put it behind the intake, its a pain.
Old Mar 30, 2007 | 04:59 PM
Mines been behind the intake for 13 years and hasn't broken yet
Old Mar 30, 2007 | 05:26 PM
SS RRR's Avatar
Exactly. Mine for 10 years even after clutch and engine swaps...
Old Mar 30, 2007 | 07:47 PM
mattbailey's Avatar
The reason I want to move it, is because it's really close to the header. The heat shield(boot) already has a small melted spot in it.
Old Mar 30, 2007 | 09:06 PM
OBE1 95Z28's Avatar
Only issue with the sensor behind the intake is when you tilt the motor for a clutch install you run the risk of it hitting the firewall. I remove my sensor when swapping clutches. Shoebox has a good photo here: http://shbox.com/1/oil_pressure_sensor.jpg
Old Mar 31, 2007 | 01:41 AM
ZBLKHELLRZR's Avatar
Thumbs up
The harness doesn't require extending it. You'll be fine. I've got mine back there as well as I'm using the other port for a mech oil pressure line. I've installed clutches in mine and never broke the sending unit either and that's w/ solid motor mounts.
Old Mar 31, 2007 | 08:08 PM
mattbailey's Avatar
Good deal! No clutches here
Old Jun 4, 2013 | 11:09 AM
JFR's Avatar
JFR
Re: Moving oil pressure sender to back of intake>>
Anyone know the part number or where to get the angle adaptor. My sender (plastic broke off)can not get it unscrewed from the angle adaptor. Looks like two 90 deg fittings.
frank
Old Jun 4, 2013 | 11:16 AM
frank
You should still be able to grab the metal base of the sensor. Whether the plastic shell is broken or not should not matter.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
