coolant temp sensor pigtail
Old Dec 18, 2007 | 09:02 PM
mdacton's Avatar
got a replacemnt pigtail but it has 2 wires. I do not have the old one or an engine harness.
question is do I use the A or B terminal? sensor has a lead in each side....both are delphi if it makes a difference
Old Dec 19, 2007 | 06:01 AM
Guest47904's Avatar
Guest
Not sure what your point is?
B is the actual signal that uses a yellow wire and goes to pin A31 of PCM Red connector.
A is ground and uses a Black/Pink wire and goes to A17 of PCM red connector. The black/pink changes color to all black after it goes thru the 10 pin connector near the PCM.
Incidentally, since the sensor is only a variable resistor, it makes no difference which contact point is used for either wire.
Old Dec 19, 2007 | 06:57 AM
I guess he might be referring to the one for the gauge that does not go to the PCM and uses one wire. I can't remember offhand, but just click the pigtail onto the sensor and meter each lead to ground to see which wire is connected to the sensor.
Old Dec 19, 2007 | 07:49 AM
mdacton's Avatar
yeah thats what I was refering to, the one for the gauge in the head. Green wire
Old Dec 19, 2007 | 11:01 AM
Stl94LT1's Avatar
Use the "A" terminal.
warmeck
Apr 27, 2015 04:34 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
91Bird305
Aug 8, 2002 12:36 AM
