Coolant sensor
Old Sep 9, 2005 | 05:41 PM
asudecat's Avatar
Coolant sensor
Well my car hasnt been running for almost 2 months now because of the re-building.
But when it was the coolant light always came on. And the coolant was not low or anything. I've had strange problems with the coolant in the past.
Sometimes the light will actually fade in and not just come on suddenly. "weird"
So im wondering if the coolant sensor is bad??
Does anyone know the Part # for this sensor??
thanks
Old Sep 9, 2005 | 05:47 PM
2000GTP's Avatar
Re: Coolant sensor
Part #25037332 and it cost 23.16
Old Sep 9, 2005 | 05:55 PM
asudecat's Avatar
Re: Coolant sensor
thanks
Does anyone know if that would possibly be the problem??
Old Sep 9, 2005 | 05:58 PM
'94 Bad A Z28's Avatar
Re: Coolant sensor
Did you properl bleed the cooling system?
There are two bleeder valves that need to be bleed to get rid of any air in the system which would cause your coolant light to come on.
Old Sep 9, 2005 | 06:03 PM
asudecat's Avatar
Re: Coolant sensor
yes
Old Sep 10, 2005 | 12:35 AM
Re: Coolant sensor
Its a very common problem for the coolant level sensor to crud up and turn the low coolant light on. If you are sure the coolant level was not actually low, you could pull the sensor and try cleaning it, or replace it.
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
91Bird305
Aug 8, 2002 12:36 AM
JurisAg02
Jul 27, 2002 11:49 AM
