coolant question
Old May 21, 2008 | 11:04 AM
1996TA's Avatar
coolant question
Well, my car's been sitting for about 4 months, as I've been waiting for some money to get er fixed. Here's what I'm going to replace (cause they're all bad/blown): radiator/cap, WP, all hoses and possibly the opti.
Question: I've been running Dexcool "orange stuff" since I bought the car (switched it from the green stuff as it needed a radiator when I got it), but recently I've had many cooling issues and am tired of dishing out the big bucks for Dexcool, would it be OK to switch back to the green stuff?
Old May 21, 2008 | 11:08 AM
Jazsun's Avatar
I thought dexcool was bad for our cars? I always use the green stuff. The orange stuff I belive is what can clump up and cause clogs.
Old May 21, 2008 | 03:25 PM
BUBBA's Avatar
Dexcool is what is called for---should be fine if you don't expose to air or mix with other coolant. If you are going to go green, go all the way. Don't mix them. JMHO
Old May 21, 2008 | 05:40 PM
caldercay's Avatar
Depends upon the year - I believe in 96, the switch was made. However,
I run Dexcool in my car with no issues.
The problem comes in if you mix the green with the gold - the whole
cooling system has to be completely flushed before switching to Dex.
Sidenote: The green and gold coolants are the same price at my local
auto parts store.
Old May 21, 2008 | 10:23 PM
joe93z's Avatar
i worked in a shop for many moons..dealer coolant and tranny fluids are highly recommened..everything else that isnt strictly performance and for your application sucks [edit]
Old May 21, 2008 | 10:43 PM
brianswimmer23's Avatar
well i run the orange stuff and like said as long as you treat it good it will treat you good just DO NOT MIX IT! but if you do want to go with the green stuff make sure you flush the system very good!
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
dansam
Jul 20, 2002 01:10 PM
