Coolant question
Coolant question
Hey all,
Just replaced the water pump on my 96Z28 like maybe two months ago or so, noticed slight coolant on the water pump but can't see any other leaks, or any profuse leaks like I had before. Anyway, my low coolant light comes on here and there, is it ok to use any coolant to refill or listen to the 16 year old jiffy lube guy and buy the expensive stuff? I have no clue. Thanks all!
Re: Coolant question
when I put my LT-1 back together it's going to the green stuff. I and others have had significant clay build up from the orange stuff. From what I understand, as long as you don't mix the 2, theres nothing to worry about.
ill probably get shot for this but... i would use Honda radiator fluid. its expensive, but it works very well. it's formulated so that it will not erode aluminum (among other things) like other fluids. my $.02. later!
jeremy
jeremy
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
