Tool to replaceTiming Cover seal?
Old Feb 3, 2005 | 11:07 AM
crazypurgatory's Avatar
I'm trying to find out what tool I need to get to take the
Timing Cover seal off?
The one behind the harmonic balancer.
I don't want to pray it out with a screwdriver and break the cover.
Anybody know what to use?
Thanks,
Chris.
Old Feb 3, 2005 | 11:13 AM
Geoff Chadwick's Avatar
Re: Tool to replaceTiming Cover seal?
they make seal pullers, grab one from even walmart. Works like a charm!
You can always try to flash heat/cool it. I had to on one of my seals. Hit it good with a torch (goodbye rubber seal) then once it was rather hot, poured ice water all over it. Then the seal puller took it right out.
Linky for a seal puller!
Old Feb 3, 2005 | 11:52 AM
Thanks I'll try the seal puller.
It's looks to big but I'll get one and give it a shot.
Thanks,
Chris.
Old Feb 3, 2005 | 12:56 PM
96camaroz28lt4's Avatar
Use a screwdriver and a hammer and it will pop out, you can bend the old seal and it won't break the cover trust me. I've replaced it plenty of times but when you replace it it will still leak a little.
Old Feb 3, 2005 | 02:09 PM
1stz28's Avatar
I've always just hooked a screwdriver or prybar tip under the metal lip of the seal and popped them out. May have to pry in more than one location to work it out but they always come out. Done thousands of seals like this.
Old Feb 3, 2005 | 02:38 PM
As have I. But getting the seal puller helps a lot on some of the more annoying ones.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
ChrisFrez
Feb 22, 2015 08:47 AM
Roadie
Feb 16, 2015 10:34 AM
