coolant problems
Old Jun 13, 2004 | 04:51 PM
zomowiec's Avatar
coolant problems
when im driving my temp is perfect 160-180, buy when i turn off my car the coolant starts to go through my reservor. I have new thermostat and new radiator cap. Any ideas? thanks
Old Jun 13, 2004 | 05:03 PM
RamAir95TA's Avatar
Re: coolant problems
As long as it runs cool when the motor is running, why worry about it when it is off?
Old Jun 13, 2004 | 09:15 PM
zomowiec's Avatar
because i have to refill coolant almost every day
Old Jun 13, 2004 | 09:16 PM
RamAir95TA's Avatar
You didn't mention anything about losing coolant. Are you leaking coolant?
Old Jun 13, 2004 | 09:17 PM
AdamZ1LE28's Avatar
Replace your radiator cap. When my car is running, I can take the cap off and it will be fine. After I shut the car off and the coolant is hot, if I remove that cap then antifreeze comes shooting out the overflow bottle.
Maybe yours leaks causing it to do that.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
warmeck
Apr 16, 2015 05:53 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
