coolant problem
Old Jun 1, 2011 | 01:28 PM
96z28_lt1's Avatar
coolant problem
alright ive searched as much as i can right now but i have to get back to work, yesterday my 96 z28 leaked coolant and was low on coolant so i topped it off. It was to late or dark for me to get uder and see where it was leaking from, also it drove perfectley fine yesterday.
Today though whenever i start the vehicle the temp spikes up to about 260 and my check gauge light comes one. After i start moving it rapidly drops back down to operating temp and then at idle goes up to the normal like 220ish range in warm weather, after work im going to check the weap hole on my water pump and try and figure out where the leak is coming from if its not there, anyone have any other suggestions where to check or have come across a similiar problem?
i also haven't done any work on the coolant system latley so theyre should be any air in the system unless do to a cracked head or bad head gasket.. but the oil also is milky...
Old Jun 1, 2011 | 01:30 PM
96z28_lt1's Avatar
Re: coolant problem
t-stat was replaced a year ago also so that probably shouldn't of failed yet should it?
Old Jun 1, 2011 | 03:31 PM
Re: coolant problem
If your radiator wasn't full, and you "topped it off", you probably have air in the system. That is the nature of the LT1's "reverse flow" cooling system. You need to bleed the system again.
Old Jun 1, 2011 | 04:03 PM
Re: coolant problem
Air in the system will cause those spikes in temperature.
Old Jun 1, 2011 | 04:29 PM
96z28_lt1's Avatar
Re: coolant problem
It was spiking earlier and I still need to find why I was leaking fluid, but I will bleed the system I mean its when the car starts it spikes then drops to normal op when I start moving and doesn't go back up passed the normal idle temp until I turn car off and on again, but ill bleed the system and check it again after I get dismissed from work
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
warmeck
Apr 16, 2015 05:53 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
