coolant problem
Old Apr 14, 2008 | 02:14 AM
2nd 2 noss's Avatar
coolant problem
so afr i read every tread on coolant, install new water pump, radiator cap, overflow cap, thremostat. and still have low coolant after car cools down. i check to see if head gasket was blown. checked for leaks. what else should i do? where should i look? what is next step?
Old Apr 14, 2008 | 12:22 PM
2nd 2 noss's Avatar
ttt
Old Apr 14, 2008 | 12:32 PM
brianswimmer23's Avatar
you mean low coolant in the radiator or low coolant light? if its low in the radiator you need to bleed a few times and fill it and then it should be good but if the light is the problem clean it and try it but if not get a new one or just disconnect it! now as far as leaks let us know if you do have any leaks once at running temp!
Old Apr 14, 2008 | 12:59 PM
2nd 2 noss's Avatar
i went out to check this morning, checked the bleeder and can hear air coming out. i hope this is the problem. thanks for the reply. I hate to have issue with a coolant system..
Old Apr 14, 2008 | 01:08 PM
ss.slp.ls1's Avatar
You fill and bleed the system with the engine off, after it has sat for a while. Cycle the engine a couple times from warm up to cool down. If it continues to be low after a couple of bleedings, you have a leak somewhere. Get a pressure tester to locate it.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
warmeck
Apr 16, 2015 05:53 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
MattFick
Feb 15, 2015 10:16 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
