coolant in oil...
Old Aug 8, 2005 | 06:46 PM
DataChild's Avatar
coolant in oil...
ok so my car has been sitting since june 19.. i had that strange really loud knocking noise, so i pulled the valve cover off and the roller rocker came off the spring and chewed up the RR... also bent the pushrod a bit. so i pulled the intake manifold off and everything looks ok.. so i ordered the parts i needed...
fast forward to today: check oil dipstick cuz im about to change the oil. oil on dipstick = black. good. i pull off oil filter. black oil. good. i then proceed to take off the oil pan screw. a WHOLE bunch of coolant comes out. not blacky coolant, GREEN coolant. after 10 seconds, a little oil comes out with it. then straight oil.
im fearing the worse. blown headgasket. along with something else i dont even know.
the intake has been off for a while, i dont know if theres any other way coolant can mix with oil without headgasket...but my car was overheating until i put more in it and yadda yadda. i thought the coolant leak was somewhere else however. so everyone in majority on headgasket?
thanks..
Old Aug 8, 2005 | 07:07 PM
mattbailey's Avatar
Re: coolant in oil...
Sounds like a headgasket sealing problem to me. BTW antifreeze isn't good on bearings.
Old Aug 9, 2005 | 04:30 AM
DataChild's Avatar
thanks man. any other input?
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
Pwilson59
Sep 3, 2015 08:47 PM
