Coolant level sensor
The coolant level sensor on the passenger side radiator on my '97 Z will not stay on properly (4 times it has popped off within 1,000 miles). I have zero confidence in the "bailing wire" that snaps on and holds this sensor in place. It may be the battery is in contact with the sensor when I drive over a bump or dip and it jolts the sensor off. The placement of the sensor is within 3/4" - 1/2" of the battery. Can I just remove the sensor and plug it closed? Or can I have the sensor PERMANENTLY installed (with mounting bracket, screws, etc) so that SOB doesn't pop off again? I check the coolant level myself anyways. The sensor works properly, but it doesn't help when I pull in my driveway and I have the sensor hanging by the 2 wires and coolant is flowing out down my driveway. Thanks, Z-monsters.
Re: Coolant level sensor
Are you sure you are getting the wire on correctly? Or maybe the little ears on the radiator are worn and won't hold it. I have not heard of anyone ever having this trouble.
yea all i can think is that your not getting it on all of the way but stranger things have happened. i really cant see where you could screw it in but hell if chuck norris could do it you can.
Make sure the port is not cracked. Mine was cracked and leaking, so I used scotchweld 2216 epoxy and a heatgun to set it quicker. It stayed in regardless. Theres a spring clip that has to wrap around the plastic flange on the port and than it sets into the two slots on the sensor, take the battery out to check to make sure the spring clip is seated, also make sure the port is not damaged.
If all else fails, unplug and remove the sensor, plug the port, and tape off the connector. You will have to be proactive in checking your engine temps and periodically checking the level in the case of a coolant leak or waterpump failure.
[B]Thanks for the advice. I ensured the clip was installed properly, and the port ears appear to be fine as well. However...that dang sensor is butted right up against my battery. Is that typical, or am I doing something wrong? I don't see any other way to remove and install that sensor other than the way it is right up against the battery. My concern (again) is that battery may shift (although it's bolted down) and cause that sensor to get bumped and I'm back at square one. Thanks again gentlemen...
http://shbox.com/1/4th_gen_tech2.html#low_coolant_lamp
There are tons of low coolant sensor threads with info.
The sensor connector is connected properly; installed pointing down. I have used the search engine on this site and I see numerous coolant level sensor issues (all being just inoperable; not actually "falling off"). The battery and the coolant level sensor are actually touching. My question I ask; "Has anyone else ever heard or seen this issue before?"
If the hold down is alright try moving the battery over towards the fender a little, enough that it doesn't touch the sensor.
