Coolant level low / low coolant light
Old May 26, 2007 | 06:52 PM
  #16
2000GTP's Avatar
Originally Posted by tfs95z28
where is the sensor?
Courtesy of Shoebox: http://shbox.com/1/low_coolant.jpg
Old May 27, 2007 | 12:43 PM
  #17
tfs95z28's Avatar
Thanks 2000GTP... Id hate to just do it and hope that is the cure... but Im running out of options!
Old May 31, 2007 | 03:42 PM
  #18
tfs95z28's Avatar
anybody else have any other thoughts before I just go and replace the sensor? Dry as a bone under the car everywhere... no leaking whatsoever.
Old May 31, 2007 | 06:31 PM
  #19
maverickmk's Avatar
I kept losing coolant with the low coolant light coming on and couldn't find it under the car anywhere as well - after about two weeks of trying to locate a leak I found that the heater core had a leak and was weeping coolant under the carpet on the passenger floor - I never have passengers and realized the problem when the floor mat starting getting dark from the coolant pooling up under the carpeting. If you continue to lose coolant and can't locate it get a pressure tester and check all the connections (all 100 of them) and under the dash as well. Good luck!
Old May 31, 2007 | 06:59 PM
  #20
tfs95z28's Avatar
that is the thing, im not losing coolant... the radiator is full all the time.
Old May 31, 2007 | 07:10 PM
  #21
2000GTP's Avatar
Its probably just a bad sensor, its not uncommon for one to go bad.
Old May 31, 2007 | 08:47 PM
  #22
maverickmk's Avatar
Sorry, I saw in your original post that you said "Im just puzzled as to where this coolant is getting consumed?" I took that as your were losing coolant.
Old Jun 3, 2007 | 03:22 PM
  #23
tfs95z28's Avatar
ok, how do i actually get to that thing? I did a half assed attempt and really saw no easy way to get at it... any quick solutions? What do I need to take out to get to it easier? Oh, and the sensor is 54 bucks at autozone! DAMN!!!
Old Jun 3, 2007 | 03:54 PM
  #24
moparman's Avatar
Take out the battery, but be sure you know your radio code if you have the OEM radio.
Old Jun 4, 2007 | 01:43 PM
  #25
tfs95z28's Avatar
nah, got an aftermarket radio... im all good there... ill try that thanks!
BMX Dad
Jan 23, 2015 07:00 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
guionM
14
Jun 19, 2002 08:30 AM
