Coolant Leak When Car Shuts Off
Old 05-28-2008, 07:31 PM
Watwood's Avatar
When I shut the car off it leaks coolant. The hotter the engine is when I turn it off, the more coolant leaks out. So, it sounds like the overflow. Do the overflow container/battery trays have a history of leaking?
Watwood is offline
Old 05-28-2008, 07:48 PM
mrmint69's Avatar
Watch it when it does it and see where it is coming from. If there is a leak it will run out if you have the overflow filled up. If it is filling up and overflowing it might be some problem or you have to much coolant in there. I think you fill it when the car is warmed up.
mrmint69 is offline
calaban
05-18-2020 06:43 PM
fpete1992
12-11-2014 03:51 PM
pologreen97z
12-02-2014 10:42 AM
blac94Z
11-28-2014 01:53 PM
USAirman93
11-24-2014 03:37 PM
Quick Reply: Coolant Leak When Car Shuts Off
