Coolant Leak When Car Shuts Off
Old May 28, 2008 | 07:31 PM
Watwood's Avatar
When I shut the car off it leaks coolant. The hotter the engine is when I turn it off, the more coolant leaks out. So, it sounds like the overflow. Do the overflow container/battery trays have a history of leaking?
Old May 28, 2008 | 07:48 PM
mrmint69's Avatar
Watch it when it does it and see where it is coming from. If there is a leak it will run out if you have the overflow filled up. If it is filling up and overflowing it might be some problem or you have to much coolant in there. I think you fill it when the car is warmed up.
calaban
May 18, 2020 06:43 PM
fpete1992
Dec 11, 2014 03:51 PM
pologreen97z
Dec 2, 2014 10:42 AM
blac94Z
Nov 28, 2014 01:53 PM
USAirman93
Nov 24, 2014 03:37 PM
