Coolant Leak
Old Apr 11, 2006 | 11:11 AM
lookingforwheels's Avatar
Coolant Leak
Hey whats up guys, I just had a new cam professionally installed and so far everything is great, runs real nice, I just have one small problem, when I'm at a traffic light I can smell coolant burning, but today I jacked the car up to change the oil, and was looking around but I can't locate where it's leaking from. The water pump looks dry, all the hoses seem dry, the only thing thats wet is the bottom front area of the motor, by where the oil pan is. Any ideas where it could be coming from?
Old Apr 11, 2006 | 12:05 PM
BUBBA's Avatar
Re: Coolant Leak
Might be the radiator petcock: I believe I have that problem. Even though the T is tight, apparently the petcock gasket may be damaged. My guess is that the mech (perhaps) unscrewed the petcock for a quicker drain of the coolant and screwed up the reinstall.
Probably not your problem, but it is a possibiity given no other obseravation. JMHO
Old Apr 11, 2006 | 12:08 PM
Re: Coolant Leak
I'll have to go check that, I've had the car running in my garage for a while now, and I can't seem to see anything leaking, is there some part of the cooling system, that only works when the car is being driven around?
Old Apr 11, 2006 | 12:10 PM
Javier97Z28's Avatar
Moderator
Re: Coolant Leak
Hey bud, the petcock was reinstalled properly and tightened up (not overtightened, i know b/c I did it ) All the waterpump bolts have thread sealant as well, and the gaskets are new and have a thin layer of RTV on them as well, all bolts were tightened down.
One thing I noticed when we put the car back together was that the weep hole area of the water pump had some coolant around it. Since it had just been off I didn't think much of it, but it was somewhat stained, so it may be starting to leak on ya
Take a good look at the bottom of the water pump and see if there's coolant around the hole now.
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Blood type Z28
Apr 8, 2015 11:34 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
dansam
Jul 20, 2002 01:10 PM
