Coolant leak = clogged cat??
Old Oct 5, 2009 | 01:31 PM
G. McDonald's Avatar
I have done a fair bit of searching/reading, but have not found a definitive answer to my issue.
A while ago, I had a coolant leak from a head porting mishap (quite a bit of coolant was lost) and was wondering if that would cause the catalytic converter on that side to become clogged. The reason I ask is that I seem to be blowing out gaskets at the header to y-pipe junction on that side, even when I put a fair amount of Ultracopper on both sides of the new gasket.
Both mating surfaces are quite flat (and are sanded and de-greased before assembly) and I have never found that any of the three bolts at that location were loose when I went back to fix the @#$%&^ problem.
As you will see in my sig, I have SLP shorty headers with the stock dual-cat Y-pipe.
If I need to replace the cat, what brand do people like? I need to pass emissions here so it must work properly, not just be a "show" cat.
Also, does anyone have a better option than the stock GM gasket that goes at that location? They are a hassle to get here, the dealership are absolute pirates and they don't seem to seal all that well.
My intention right now is to get some of the hi-temp gasket sheet and make my own, using Ultracopper again.
Thanks for the input, gents.
Old Oct 5, 2009 | 01:46 PM
SlowMoComotion's Avatar
when you say leaking coolant. do you mean that its burning coolant and you think this is clogging your cat?
Old Oct 5, 2009 | 01:54 PM
Yes, coolant going through the combution chamber
The coolant leak was near the valve inside the intake runner and was sending a fairly large quantity of coolant through the engine and in turn, through the driver's side cat.
Old Oct 6, 2009 | 08:31 AM
pizzi-man's Avatar
A cloged cat will eat exhaust gaskets as you will have extream back pressure and the exhaust will need to go somewhere. The motor will also lack power and run like **** because of the back pressure pushing exhaust gasses back into the combustion chamber during overlap. Your mpg will also drop like a rock.
Old Oct 6, 2009 | 09:56 AM
How can I confirm the cat is blocked?
I thought I read somewhere that I could confirm a blocked cat by taking some temperature readings. I have a temperature probe on my multitester which would allow me to do that.
Can anyone put me onto a how-to for that procedure and let me know what readings I should see at certain locations in order to rule out or confirm a plugged cat?
Thanks for the input.
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Blood type Z28
Apr 8, 2015 11:34 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
dansam
Jul 20, 2002 01:10 PM
