coolant hoses on back of heads
Old Mar 2, 2004 | 11:04 PM
sharp396's Avatar
on my 96 these hoses connect and run to the small port right below my radiator cap. Should there be fluid flowing through this port into the radiator or is is just for steam?
thanks
Old Mar 2, 2004 | 11:06 PM
94 CAMRO Z28's Avatar
Im pretty sure its for steam but im sure someone else and confirm this.
Aaron
Old Mar 2, 2004 | 11:25 PM
442olds's Avatar
Once all the air pockets have worked their way out of the system it ussually flows coolant. Its a good way to see if you have removed all the air from the system.
Old Mar 2, 2004 | 11:31 PM
Sweetred95ta's Avatar
Yeah, I'm pretty sure those are supposed to flow fluid through them.
Benji
Old Mar 2, 2004 | 11:53 PM
sharp396's Avatar
Thanks. I guess I will bleed the system a few times and see what that does.
Old Mar 3, 2004 | 12:02 AM
JJ's95B4C's Avatar
I pulled the drivers side head last weekend and the crossover tube was leaking a small amount of coolant...if that helps any?
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
Jazsun
Dec 29, 2014 12:14 PM
pologreen97z
Dec 2, 2014 10:42 AM
cristian1311
Nov 23, 2014 02:22 PM
