Coolant hose question
Old Apr 28, 2006 | 02:36 PM
93 4mula's Avatar
Ok guys picture this in your head cause it sounds confusing. The coolant hose that runs in front of our alternators that goes to the waterpump and has the bleeder valve on it, It has the little T coming off of it so that the hose can run to your throttle body. I have seen some pictures that they T isn't even there anymore. Do they make a replacement or is everyone just cutting theres off and tigging the hole shut?
Old Apr 28, 2006 | 04:23 PM
Type_O_Negative_1320's Avatar
Re: Coolant hose question
I shoved a bolt (along with some RTV) into what was left of the hose going to the throttle body after I clipped it and put a hose clamp on it. It's still in there and has been holding with no leaks for ~4 years.
I bought a 95-97 heater hose assembly to swap in since it eliminates the stupid T-junction, but the torx bolt holding the assembly to the shock tower is stripped thanks to me not being able to see which size bit I needed to remove it. The assembly is also somewhat expensive (part #10261147, $81 from Dal). You can go that route if you have the money to spare and can actually manage to get the damn bolt out.
Old Apr 28, 2006 | 04:49 PM
93 4mula's Avatar
What exactly is Dal?
Old Apr 28, 2006 | 04:56 PM
MeanGreen97Z's Avatar
He is a guy. Get his contact info from shoebox's website.
Old Apr 28, 2006 | 05:38 PM
93 4mula's Avatar
So on 95-97 Firebirds and camaros that T isn't on the coolant hoses?
Old Apr 28, 2006 | 09:03 PM
Correct. You can view the different hose configurations on my website.
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
pologreen97z
Dec 2, 2014 10:42 AM
cristian1311
Nov 23, 2014 02:22 PM
