coolant flush question
So I'm replacing the radiator in my TA and I was going to do a coolant flush to make sure all the old crap is out of the block and what not. Is it possible to just flush out the block? I understand how it works when you have the radiator still in but I was trying to do it while the radiator was out to just flush out everything in the system. How would I go about doing this?
At the bottom of the block, on each side of the block, near the motor mounts, is a drain port. On the driver's side there is a pipe plug in the hole. On the passenger side, the knock sensor is screwed into the hole. You open those to drain the coolant that is in the bottom of the block. You could leave them open and flush everything out.
Shoebox has a photo of the passenger side:
http://shbox.com/1/ks.jpg
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
