coolant fans
Old 08-09-2003, 03:03 PM
red 95 z28 lt1's Avatar
coolant fans
i have my coolant fans programmed to come on early by a hpp. question is, sometimes they wont go on and the temp will rise in traffic. i check the relays and there are 3 cooling fan relays. can anyone tell me which each one is for. also i swapped a couple of relays around and the fans turned on and havent had problems could i have a bad relay somewhere?
red 95 z28 lt1 is offline
Old 08-09-2003, 03:17 PM
Lyle A's Avatar
I would say that if you swapped relays and the problem went away then you either have a bad relay(try to remember which ones you swapped) or you had a bad connection and solved it by unplugging and plugging relays. On the relays, one is for low speed or 1 fan and the other two are for high or both fans. Make sure all your ground connections are good . A loose or broken ground wire can cause problems too.
Lyle A is offline
Old 08-09-2003, 04:28 PM
thank you very much. i will look into that!
blac94Z
02-15-2021 09:43 PM
Magenta_Hearts
03-29-2017 08:54 PM
Biggiebound
04-23-2015 08:50 AM
MattFick
02-15-2015 10:16 PM
AlaskaZ28
01-01-2015 12:30 PM
Quick Reply: coolant fans
