coolant fans
Old Aug 9, 2003 | 03:03 PM
red 95 z28 lt1's Avatar
coolant fans
i have my coolant fans programmed to come on early by a hpp. question is, sometimes they wont go on and the temp will rise in traffic. i check the relays and there are 3 cooling fan relays. can anyone tell me which each one is for. also i swapped a couple of relays around and the fans turned on and havent had problems could i have a bad relay somewhere?
Old Aug 9, 2003 | 03:17 PM
Lyle A's Avatar
I would say that if you swapped relays and the problem went away then you either have a bad relay(try to remember which ones you swapped) or you had a bad connection and solved it by unplugging and plugging relays. On the relays, one is for low speed or 1 fan and the other two are for high or both fans. Make sure all your ground connections are good . A loose or broken ground wire can cause problems too.
Old Aug 9, 2003 | 04:28 PM
thank you very much. i will look into that!
blac94Z
Feb 15, 2021 09:43 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
Biggiebound
Apr 23, 2015 08:50 AM
MattFick
Feb 15, 2015 10:16 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
