coolant fan
Old Feb 20, 2007 | 12:18 PM
gwturbo's Avatar
coolant fan
Apparently I have a coolant fan problem. While the car is moving it cools fine. but as soon as I get in traffic or lights the temp begins to climb. I have a 97 Lt1. I am new to this vehicle. Most likely cause? Relay?
Any input appreciated
Thanks, Glenn
Old Feb 20, 2007 | 12:22 PM
BUBBA's Avatar
As a new member, go to Shoebx.com to begin with and then do search on this site. After these 2 steps come back to site and see if you get any onter responses.
Old Feb 20, 2007 | 12:29 PM
BUBBA's Avatar
oops: make that sh.box.com
Old Feb 20, 2007 | 12:39 PM
That would be http://shbox.com/1/4th_gen_tech1.html.
All cars with electric fans heat up when you stop. That is normal.
Info.
Old Feb 20, 2007 | 12:56 PM
BUBBA's Avatar
Right: shbox.com---I was getting closer and eventually would have given the correct site, but noooooooooooooooo.
Old Feb 20, 2007 | 01:05 PM
gwturbo's Avatar
Shoebox and Bubba. Thanks very much. Good info. I don't think I have near the problem I thought I had. Thanks again, Glenn
Old Feb 20, 2007 | 01:28 PM
I didn't know how many pages of posts it would take to get it right, so I thought I would save you the trouble.
Old Feb 20, 2007 | 01:30 PM
BUBBA's Avatar
no more than about 5 or 6 more and I would have nailed it. But thanks anyway shoe.
Buff_SS's Avatar
Thanks, Glenn
More than likely a relay. Hopefully not an ECU signal interuption. Those can be a pain to track down.
Old Feb 20, 2007 | 02:30 PM
2000GTP's Avatar
Doesn't sound like he has a problem at all, just normal for the conditions in which he is driving. If his temp gauge was pegged in the red, then I would start to worry. You also have to figure these cars do run warm from the factory.
blac94Z
Feb 15, 2021 09:43 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
Biggiebound
Apr 23, 2015 08:50 AM
MattFick
Feb 15, 2015 10:16 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
