coolant creeping up head stud (external stud)
Old Sep 28, 2009 | 09:45 PM
97SS0594's Avatar
noticed it at the track.. at one of the head studs on the water jacket side of the head of the stud is outside the head. its only when its warm. it was petering out. at 1st i thought i lifted a head but it was only comming out of that 1 stud, and none out arount the head gasket.
Old Sep 28, 2009 | 09:59 PM
The obvious would be the stud(s) is/are not sealed. Seems to happen to a lot of people with studs. What was used to seal them?
Old Sep 28, 2009 | 10:06 PM
97SS0594's Avatar
previous owner installed them, id assume RVT sealant... but my concern is will it cause a problem?
Old Sep 28, 2009 | 11:03 PM
Heck yeah, it's going to be a problem. The cooling system is meant to be sealed tight. I would be concerned that if one was leaking, others will too (and inside the valve cover). Cooling passages can get clogged by RTV. I would not use if for sealing threads. A non-hardening sealer should be used.
Old Sep 29, 2009 | 02:18 PM
ACE1252's Avatar
I like this stuff....
http://www.permatex.com/products/Aut...ad_Sealant.htm
Old Sep 30, 2009 | 05:16 AM
1982z28with18s's Avatar
As I always say when this comes up, USE #2 SEALANT, only use this stuff. I along with quite a few others have never had a problem using it on head studs, while others use the arp sealant, other thread sealants, rtv, etc, etc and it all leaks.
Old Sep 30, 2009 | 10:27 AM
Z28SORR's Avatar
Brand name???
Old Sep 30, 2009 | 10:40 AM
wrd1972's Avatar
Originally Posted by ACE1252
I like the above stuff too.
The permatex #2 seems very "slick" for some wierd reason and I would be worried about something coming loose. I noticed this once when I used it on rocker studs.
Old Oct 1, 2009 | 03:23 PM
mrmikelt1's Avatar
use pipe dope
Old Oct 2, 2009 | 08:36 AM
Have you let it set up then touched it, its very tacky.
DirtyDaveW
Mar 15, 2015 07:01 PM
armedtrigger
Feb 24, 2015 08:30 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Catmaigne
Dec 25, 2014 12:16 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
