Coolant bubbling out the overflow???
Old Nov 26, 2016 | 06:50 PM
  #16
Rkempton's Avatar
Re: Coolant bubbling out the overflow???
Originally Posted by henryz28
Could be the two small hoses that run to the top of the radiator; or just below the cap. I had mine switched and it will heat up and run out the overflow. Make sure that the hose running to the overflow is the one on top; or the first hoes below the cap.
This problem drove me nuts. I couldnt figure out why my resovour and radiator was dumping all the coolant after putting in a new oem thermostat. Switched the hoses and issue resolved. Thankyou
Old Aug 29, 2019 | 10:01 PM
  #17
Mrfixit1's Avatar
I have the same problem it my lines are right new water pump doesn’t overheat but pushes water to the resavor new radiator cap 18 lbs and new therm
Old Aug 29, 2019 | 11:09 PM
  #18
Did you use the correct LT1 t'stat?
http://shbox.com/1/tstat.jpg
When you open the radiator cap, is the coolant all the way to the very top of the fill neck, no air space? Possibly a cracked overflow hose, or a hole in the metal tube it connects to, on the reservoir, under the battery? That prevents the vacuum from pulling the coolant back out of the reservoir as the system cools down, to keep the radiator filled to the top.
Did you thoroughly bleed all the air out of the system?
4th Gen LT1 F-body Tech Articles
Jason E
Apr 22, 2008 08:01 PM
green.Z
Nov 11, 2007 11:16 PM
nb 96 z
Dec 20, 2005 07:46 PM
blaze309
Aug 14, 2005 10:44 PM
Crackhead
Nov 23, 2003 07:18 PM
