Help! overheating and coolant overflowing
Old Dec 20, 2005 | 06:01 PM
nb 96 z's Avatar
Well the car just about overheats and all the coolant overflows out of it. Put more in to get me home and it overflowed that too. what's the problem?? thermostat? radiator cap? Just did a coolant flush in early november.
Old Dec 20, 2005 | 06:13 PM
km9v's Avatar
Re: Help! overheating and coolant overflowing
Sounds like a thermostat. Get a fail safe type.
Old Dec 20, 2005 | 06:47 PM
hektyk's Avatar
I concur. The easiest way to check is when your engine is running warm squeeze the top radiator hose and see if you can feel the coolant going through it. You can also take it out and put it in a pot of water on the stove then see if it pops open. Of course they are pretty cheap so you might as weel just change it and see if that works.
Old Dec 20, 2005 | 07:32 PM
nb 96 z's Avatar
well i just changed the t-stat and filled it back up and all the coolant started leaking out the hole on the bottom of the water pump. What happened??
Old Dec 20, 2005 | 07:36 PM
nb 96 z's Avatar
is my waterpump bad??
Old Dec 20, 2005 | 07:41 PM
joeSS97's Avatar
Yes it is.
Old Dec 20, 2005 | 07:44 PM
nb 96 z's Avatar
sweet.
Old Dec 20, 2005 | 07:46 PM
nb 96 z's Avatar
how come it didn't leak out the bottom to begin with??
Formula Steve
Sep 19, 2023 08:31 AM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
