Converting ODBII to ODBI Speed Density
Old Jun 17, 2003 | 02:31 PM
Brettinator's Avatar
Question Converting ODBII to ODBI Speed Density
I have a 97' Z28 ODBII and would like to know if I could convert to a 93' Formula ODBI Speed Density? If so is there a link explaining the conversion of hardware. I have everything I need as for computers and can even burn my own chips with my CATS software but I am not sure what I need to do on the hardware side. I'm sure the MAF would be no more but any help would be appreciated.
__________________
Old Jun 17, 2003 | 02:35 PM
madwolf's Avatar
Just swap harnesses and use the 97 opti harness on your 93 engine wiring harness. You'll also need to swap the current knock sensor to a 93 one. Other than that, you don't need anything else.
Old Jun 17, 2003 | 02:43 PM
But I have a 97 and my friend has the 93 I don't have his harness, just his computer, and the ability to burn the chips with CATS software. Or did I misunderstand what you said Wolf? Thanks.
Old Jun 17, 2003 | 02:54 PM
madwolf's Avatar
Well if you want to convert to JUST speed density, your PCM can be reprogrammed for it. If you want to convert to a 93 ECM setup, you will need the 93 harness as well because the connectors are totally different.
Old Jun 17, 2003 | 02:57 PM
DAMN... I was hoping to just do minor stuff to convert. Just because I could tune my own stuff without going to some shop paying 400 bucks or sending it off to PCM for less blah blah ....a wiring harness sounds like a pain and more than I want to tackle for now. I guess I'm back to looking for a bootleg copy of LT1 EDIT for ODBII ...be a cold day in hell
Old Jun 17, 2003 | 02:59 PM
madwolf's Avatar
Not that I would recommend it, but you won't be able to get a bootleg copy of OBDII lt1_edit (and not even OBDI lt1_edit). They have special cables which are VIN locked.
You can either convert to OBDI and get programming software for like $90 or have your OBDII programmed instead. I can help with both if you're interested.
Old Jun 17, 2003 | 03:02 PM
Not that I would recommend it, but you won't be able to get a bootleg copy of OBDII lt1_edit. They have special cables which are VIN locked.
I was aware I couldn't I was jez bored and pissed. But yes I am interested in doing something where I can program my own stuff. So do you recommend say like a 95 ODBI and does that harness interchange just fine? They do that here in Houston all the time but I'm just not familiar with what all is involved. I don't care about getting my ODBII tuned unless I can do it myself, I want the independent ability. And yes I'm aware of LT1 EDIT for ODBII for $500 bucks and would consider it maybe when the stroker was done.
Old Jun 17, 2003 | 03:05 PM
madwolf's Avatar
Harnesses will interchange, you will just need a 94-95 PCM and a 94-95 knock sensor in the block, or if you're getting an OBDI conversion, you won't need to swap the knock sensor.
Old Jun 17, 2003 | 03:14 PM
kgkern01's Avatar
Is it better to go speed density or MAF?
Old Jun 17, 2003 | 03:16 PM
ok well cool then....so how can you help me? Can you get an ODBI for me? If so how much?
Old Jun 17, 2003 | 03:18 PM
madwolf's Avatar
Check my website's order page.... www.madz28.com
As far as the other question, I like MAF systems much more than Speed Density ones. And just think that almost all of today's (at least GM) applications are MAF based...
DirtyDaveW
Dec 1, 2016 05:37 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
ChrisFrez
Feb 15, 2015 07:49 AM
Jul 4, 2005 05:00 PM
