Converting heads to reverse cooling
Old Jan 7, 2008 | 08:41 PM
SS1156's Avatar
I have a chance to get a set of beautiful Bow Tie heads that have been worked and flow awesome. I can get them for a very good price. I was wondering what has to be done to convert them to reverse cooling?
Old Jan 8, 2008 | 09:37 PM
slomarao's Avatar
search in advanced tech, there are a few threads you ll find. Roughly it costs 500 because of the coolant passages and head bolts holes need to be altered.
Old Jan 8, 2008 | 10:18 PM
FASTFATBOY's Avatar
No head bolt holes have to be moved.
You have options, You can do like I did. RHS 235 heads converted BUT....I did not weld and redrill the intake side of the head BECAUSE I used a super Vic Carb style intake, I did not drill the rear of the head for the coolant crossover because I used the two rear holes in the Super Vic "T'ed" them together and ran it to the radiator.
ALso one hole for the acc bracket has to be drilled in the head on the passenger side.
Contact CFM in Indy Or Port Pros.
David
PCLZ28
Dec 24, 2015 05:19 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
MattFick
Feb 15, 2015 10:16 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
