Converter Lockup ??
Old Jul 23, 2003 | 02:16 PM
ZaneO's Avatar
Converter Lockup ??
Do the converter's in LT1's automatically lock up on the dyno?
Old Jul 23, 2003 | 02:20 PM
IrocManiac's Avatar
It should yes.
Old Jul 23, 2003 | 02:27 PM
LWillmann's Avatar
The converter shouldnt' be locked at WOT should it?
I thought that it only locked in 4th gear anyway, and the A4 is 1:1 in 3rd so it wouldn't lock up then anyway...
Chris 96 WS6's Avatar
Actually the answer is no. The stock program commands the converter to stay unlocked at WOT. It might lock when you get it up to speed but once you go WOT for the pull it will unlock.
If you install a lockup switch or program it to lock at WOT (this is hard on the lockup clutch, can burn it up eventually) your HP will be higher...more comparable to an M6 dyno pull because you will be removing the power-robbing converter slip.
If you put the shifter into 3rd and cruise it will lock up in 3rd...but in normal driving it will go to 4th before it has as chance to lock in 3rd.
Old Jul 23, 2003 | 03:35 PM
ZaneO's Avatar
Very interesting. I had heard that it did, but wasn't really sure if it did or not.
Old Jul 23, 2003 | 03:43 PM
IrocManiac's Avatar
If it didn't lockup on a dyno pull wouldn't that distort the numbers? I was pretty sure it did lockup?
Old Jul 23, 2003 | 06:20 PM
TimChiaretto's Avatar
According to the tables in LT1 Edit at anything above 50% TPS in 3rd gear the converter will not lock. The same goes for 4th gear.
Old Jul 23, 2003 | 06:23 PM
The fact that the converter does not lock is why A4 dyno numbers are always lower than the same setup with an M6.
Old Jul 23, 2003 | 06:54 PM
IrocManiac's Avatar
Hell I guess that makes sense...kinda wierd I figured it'd distort torque numbers like crazy if it didn't lock up...guess I was wrong...
Old Jul 23, 2003 | 08:22 PM
mikem94Z's Avatar
How would you go about installing a lock up switch for one of these to use at the track.Done it on a Buick GN before by just grounding a terminal on the ALDL connector.How are you guys doing it on these cars?
Old Jul 23, 2003 | 08:37 PM
rskrause's Avatar
Moderator
It's not designed to lock up under WOT and would probably break.
Rich Krause
Old Jul 23, 2003 | 09:13 PM
Agreed. You can wire up a switch for OBD1 cars easily, OBD2 it doesn't seem to work or work well. But like Rich said, I would not recommend making a habit of locking it under WOT..the clutch will eventually burn up and you'll lose your lockup all together.
VIgilante sells a multi-clutch disc converter if you want to lock up under WOT.
For the switch, just do a search for lockup switch...there are several posts on the subject.
NewsBot
Sep 14, 2015 02:02 AM
95craz28
11
Sep 12, 2015 07:47 AM
USN06
Sep 7, 2015 03:30 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
95_lt1_z28
Aug 30, 2015 06:17 PM
