Control Arms
Control Arms
Just bought some control arms, what do you guys think, easy to do, hard? I looked for some install pages but couldnt find one. Also how much to get them installed if I need to go that route?? Thanks
Rear LCA's are easy. Just do one at a time so as not to let the rear end move on you and make things difficult. You'll probably need to actually pull the rear end to you to get the front hooked up so I did mine with tire chalks in neutral.
Not hard at all, the only thing I didn't like about installing mine was getting the lca bolts out. I've done them on both of my cars and have had the same problem with both of them, the lcas bolts are always a huge pita to get off. Make sure you give them a couple shots of penetrating oil the day before you're gonna install them.
alright thanks guys. Doesnt sound that difficult, just have to wait till they come to try this out. If I wanted to get them installed for me what do shops usaully charge? I have to get my subframe connectors welded in also
