Cam Swap questions, are these all the gaskets I need? and more :)
Old Feb 27, 2003 | 12:16 AM
Javier97Z28's Avatar
Moderator
Ok, should be ordering my cam kit from cmotorsports soon
Here's what I'll be getting.
N224K
Comp Cams Xtreme Energy 224/230 Cam .536"/.544" Lift
Comp Cams Pro Magnum 1.6 Rocker Arms, Self Aligning
CM612 Valve Springs
CM126 Chromoly Retainers
CM007 7 Degree Hardened Locks
GM LT4 Extreme Duty Timing Set #12370835
Gaskets
Intake Manifold Gasket Kit #12524653
TB Gasket #10105379 (plan on cleaning up my TB and removing it)
Timing cover gasket #10128293
Opti Seal #12552428
Water Pump Gasket #10128343
WP Drive Seal Gasket (I'll order 2 just in case) #12553792
Will this do it? Thunder wants like $84 for the kit with all the gaskets but it has stuff I don't need like EGR gaskets and valve cover gaskets which IMO can be reused no problem. And if it can't it's common enough to pick up locally after the fact.
Am I goign to need anything else? Aside from some Dino oil for startup and some synthetic for afterwards.... (and coolant)
Old Feb 27, 2003 | 05:30 AM
jkipp84's Avatar
For the timing cover/opti/water pump, I'd get (and did) the Felpro kit at Autozone. It will have all of that crap for about $14. They'll also have Felpro intake gaskets (dunno about the TB one though) if you want.
Don't forget coolant!
New lifters? I went Crane's when I did my swap. BTW - looks like the same combo I'm running right now. You're going to have a blast when it's done
XE 224/230, Pro Mags, Cloyes, CSI, etc..
Old Feb 27, 2003 | 08:24 AM
Moderator
Hmm about the lifters, most of what I read has indicated that unless there is an actual problem with the lifters they are generally fine under .550" lift. The car's got 73k miles on it and has not skipped a beat, running perfectly. How much did the Crane's run ya?
Sounds like a good price on the FelPro Kit .. I'll have to stop by and get that instead. Thanks!
Old Feb 27, 2003 | 08:28 AM
Smoke T/A's Avatar
I ran a cc306 with stock lifters for 8 months with no problems.
Don't forget about the rubber seals for the crossover tube that runs to the back of the heads. They are kinda pricey about $3-4 a seal and you need 4
Old Feb 27, 2003 | 08:37 AM
Moderator
I'm not pulling the heads, just a cam swap (this time )
Old Feb 27, 2003 | 09:02 AM
MEAN LT1's Avatar
Make sure you have a dremmel tool to scrub all the old gasket off the throttlebody,waterpump,intake manifold, and the timing cover. The dremmel tool make things alot easier, that old gasket crap in a pita to take off sometimes. Oh...and dont forget about about the oilpan...another pain in the azz to get to especially if your an automatic. You have to disconnect the coolant feed for the tranny to get to some of the bolts for the oil pan. I resused my old lifters and havent had a problem out of them yet. Im using comp918 double coil springs for my 224/236 blower grind cam. Same duration but not as much lift without the 1.6rr. Good luck!
Old Feb 27, 2003 | 09:13 AM
jkipp84's Avatar
One more thing - 11/32 Umbrella type valve seals.
As for the lifters - sure, if the stockers are ok, no point in spending the $$ on new ones. I did my cam swap at about 102k miles... I felt lifters were needed.
Old Feb 27, 2003 | 04:32 PM
Moderator
Dremel Tool.. check! got that thanks for the tip, i'll go buy some more wheels for it...
Valve seals... is this just a stock replacement type thing I should do while I'm in there? Never really torn into a valvetrain before, so anymore info on that would be great
Old Feb 27, 2003 | 05:00 PM
AlexA's Avatar
I'm not sure why you'd need a TB gasket - it's rubber and IMO, reusable.
-Alex
Old Feb 27, 2003 | 05:01 PM
Moderator
-Alex
it's $2 if it rips for some reason, I'll have one
Old Feb 27, 2003 | 06:37 PM
WJH'sFormula's Avatar
ditto on the felpro timing gasket set...
also, dont forget about gasket sealant, thread sealant and oil
be sure to budget for beer and all that good stuff too
luck-
Old Feb 27, 2003 | 08:52 PM
AlexA's Avatar
Hehehe...if you rip it, you are REALLY trying. Well, I can't recall if the STOCK gasket is paper, but mine is a thick rubber gasket - it should last forever.
-Alex
Old Feb 28, 2003 | 01:46 PM
Moderator
luck-
yes! haha! pizza/beer/cars go hand in hand
i'm all set for gasketn sealant.. do need some more thread sealant and I will be getting dyno oil and synthetic oil for post break in.
so do I pretty much have everything I will need?
InfernalVortex
Jan 17, 2015 09:35 AM
chuyz28
Jan 15, 2015 04:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
chuyz28
Nov 25, 2014 11:14 PM
