Control Arms
Old Feb 28, 2003 | 09:38 AM
Grn96Z's Avatar
Control Arms
Just bought some control arms, what do you guys think, easy to do, hard? I looked for some install pages but couldnt find one. Also how much to get them installed if I need to go that route?? Thanks
Old Feb 28, 2003 | 10:10 AM
93ZM6Tally's Avatar
Rear LCA's are easy. Just do one at a time so as not to let the rear end move on you and make things difficult. You'll probably need to actually pull the rear end to you to get the front hooked up so I did mine with tire chalks in neutral.
Old Feb 28, 2003 | 10:30 AM
stik6shift93's Avatar
Not hard at all, the only thing I didn't like about installing mine was getting the lca bolts out. I've done them on both of my cars and have had the same problem with both of them, the lcas bolts are always a huge pita to get off. Make sure you give them a couple shots of penetrating oil the day before you're gonna install them.
Old Feb 28, 2003 | 11:36 AM
Grn96Z's Avatar
alright thanks guys. Doesnt sound that difficult, just have to wait till they come to try this out. If I wanted to get them installed for me what do shops usaully charge? I have to get my subframe connectors welded in also
Old Feb 28, 2003 | 12:38 PM
Grn96Z's Avatar
Anyone know where I could find an install page, or possibly know prices to get them installed?
Old Feb 28, 2003 | 01:05 PM
RedRyder518's Avatar
https://www.hotchkis.net/frames/instructions.htm
-and-
http://bmrfabrication.com/instructions.htm
Old Feb 28, 2003 | 01:34 PM
One more thing, make sure your rear suspension is preloaded when you tighten the bolts down.
Slayer
Aug 17, 2015 03:55 PM
KYWes
Aug 10, 2015 07:03 PM
realistyc
Jul 28, 2015 07:32 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
