constant metal on metal scraping sound - coming from alternator area - help!
Old Jun 14, 2003 | 03:32 PM
sc93's Avatar
Ok, 93 Z28 A4. When I start it up, I hear a sort of grinding sound that increases with RPM's. I can tell that it is coming from the alternator area, or below around the A/C pulley. I haven't run the A/C for about a year, and I just used it and now this happened. Could anything be wrong with the pulley itself? Maybe it is sticking or grinding against something?
I am lost! Help!
Old Jun 14, 2003 | 03:44 PM
snake_skinner93's Avatar
how does your transmision shift? ok, no probs? i had a '93 A4 Z and one time i started my car and all the sudden it sounded like a power saw just cutting away at something! i was like.. so, it quit and about a month later i was replacing my transmission due to melted clutches. it sounded just like it was coming from under the hood, but it was the tranny all along. just somthing to think about.
Old Jun 14, 2003 | 03:47 PM
sc93's Avatar
Actually I'd been having problems with the tranny, not shifting at a high enough RPM and not downshifting correctly.
Old Jun 14, 2003 | 03:57 PM
Mtrhds94Z's Avatar
I just had that noise.. and it was the tensioner [not just the pulley bearing, but the actual tensioner.. the 'spring' is somehow worn thru the housing...]
Really was squeeking/squealing loud...
Might be worth a look...
Old Jun 14, 2003 | 06:08 PM
sc93's Avatar
Thanks, I'll look at that. My serpentine belt is pretty worn and kinda cracked too, I will probably replace that. But mine isn't really squeaking or squealing, it's more of a scraping sound along with what sounds like an old style roots blower under the hood. I'm getting the metal scraping sound and a loud whine. It doesn't sound like the alternator going bad either, but I won't rule that out
Old Jun 14, 2003 | 06:41 PM
Amped96's Avatar
Get a piece of pipe and put it up against the alt and put you ear on the other end and listen to it. Do the same to the A/C compressor. It is a good way to tell where a noise is coming from.
Old Jun 15, 2003 | 02:14 PM
sc93's Avatar
Ok I put a piece of pipe against the alt and put my ear up to the other end. the sound got alot louder so I am thinking its my alternator.
anyone have a part # for a 93 LT1 alt? Or a suggestion for a new one?
Old Jun 15, 2003 | 05:48 PM
Amped96's Avatar
I have always had good luck with NAPA alternators. I can NOT say the same for autozone alternators however.
vb95z28conv
Jan 27, 2015 08:32 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
squarehead
Nov 21, 2014 08:02 PM
Evilfrog
Aug 7, 2002 11:36 PM
