Connecting to the switched power block
Old Jul 30, 2003 | 10:54 PM
JSK333's Avatar
Hey guys.
What kind of wire connector do I need (or how do I connect it) to connect a hot wire for an ignition timing retard module to that little dist. block in the fuse box connected to the orange wire?
I can tell that the orange wire is 12V switched power, and right next to it is an open terminal kind of thing... but I can't figure out what kind of connection it is. I need to get my 18ga power wire permanently connected to that.
Can anyone help me out?
TIA!
Old Jul 30, 2003 | 11:28 PM
You can just put a spade tip on the wire and plug it in, like it was one leg of a fuse.
Old Jul 31, 2003 | 09:51 AM
JSK333's Avatar
Spade tip? Is that a male connector? Because this one called a "spade terminal" (http://www.radioshack.com/product.as...5Fid=64%2D3127) sure doesn't look like it'd fit this terminal on the fuse box.
Are you talking about the connectors that have male plugs that are flat thin pieces of metal that insert into female connectors that are flat and thin enough for the male plug to enter? They're called "quick disconnect" type (http://www.radioshack.com/product.as...5Fid=64%2D3132).
Or another kind? I tried the one above and the male plug won't fit into that terminal.
Is it a "bullet terminal" (http://www.radioshack.com/product.as...5Fid=64%2D3047)?
Hopefully it's one of the above. Please let me know what you think. Thanks again for your help.
EDIT: I think I realize what you're saying now... you mean I should plug it in on the TOP side of the fuse box, not underneath where the orange wire connects, right? If so, then I'd think I'd need a male quick disconnect connector, right?
Old Jul 31, 2003 | 11:16 AM
Yeah, that is what I mean. Plug it in on the fuse side.
Old Jul 31, 2003 | 02:49 PM
JSK333's Avatar
Well, I can't do that because the terminal is already taken up by a fuse.
How else can I do this?
Old Jul 31, 2003 | 05:18 PM
Do you see the three single terminals in the fuse box? They are marked "batt", "ign" and "accy". The batt one is constantly powered. Ign is powered with the key ON or START. Accy is powered in ON or ACCY.
Just plug in there.
Old Jul 31, 2003 | 07:47 PM
JSK333's Avatar
Oops, sorry, I thought I had mentioned it in the first post, but I didn't.
I am talking about the fuse box under the hood, not the one on the driver's side of the dash.
Old Aug 1, 2003 | 04:45 PM
JSK333's Avatar
So does anyone know of an ignition ON/START switched power source under the hood?
Please help!
Solomon
Old Aug 1, 2003 | 07:53 PM
Anything on the load side that is pink should be switched power. Orange is usually hot all the time. Check with a meter or test light if needed.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 23, 2015 01:13 PM
Jul 4, 2005 05:00 PM
XtremeLt1
Sep 13, 2002 08:50 PM
Ryabut98
Sep 3, 2002 11:45 PM
