Cleaning Combustion Chamber And More
Old Jul 25, 2003 | 03:02 PM
95 WHITE TRANS's Avatar
I'am going to clean my iac ,throttle body, and combustion chamber tomorrow,I bought a new gasket for the throttle body,do i need any other kind of gasket for this job.I bought cleens combustion chamber conditioner from gm, kleen flo throttle boby cleaner,and kleen flo fuel injector cleaner.Has anybody here cleaned their combustion chamber and what products have you used.How were the results,is it safe for the aluminium heads.
THANKS
NICK
Old Jul 25, 2003 | 09:06 PM
BigRich's Avatar
i just did the annual Sea Foam/Deep Creep tx
shot the s*** out of the throttle body w/ the Deep Creep, used like 1/3 of the can
did the sucking brake hose thing too
do it while the engine is hot, it's much better
i drove to the ritzy neighborhood of Kahala to do mine, then i fogged the s*** out of em!!!! funny as hell
Old Jul 26, 2003 | 01:28 AM
MentalCaseOne's Avatar
Hey I wanna FOG Kahala too!!
Old Jul 26, 2003 | 01:33 AM
90MustangGT's Avatar
Get the engine hot, spray about a bottle of Carb cleaner down the TB. Use something lighter on the MAF lines, they are easily broken, and change the plugs.
Old Jul 26, 2003 | 01:50 AM
I SAID I WANNA FUC ERR NO .... I MEAN *FOG!* KAHALA TOO!!!
Old Jul 26, 2003 | 01:53 AM
Honestly.....how much SeaFoam should I put in the engine? I am gunna do it this weekend.
Marvin
Old Jul 26, 2003 | 04:46 AM
scoobysnax83's Avatar
Marvin
Whole can through the brake booster cable. It took me 25 miles to blow it all out. But it sure was fun fogging the hell out of everything. Gosh, I love seafoam
Edit: Just for a few facts. My engine has been seafoamed since day one every 10,000 miles. Plugs, opti and O2's did not have to be changed until 153,000 miles. Plugs looked like they could have been in longer, but Opti crap went, so I figured it was a good time to change them. 10,000 miles later and still no problems.
Old Jul 26, 2003 | 11:04 PM
25miles!!!!!!!!!!!!! If I get the Hawaii PD on my tail I bet its gunna look like the first Hawaiian speed chase in History!!!
I bet I will be in the 12 o'clock news too... maybe even the guiness book of records!!! Heck a 25miles fog will defenetely fog the WHOLE FRIGGING ISLAND!!!!!.
I SAID I AM MENTAL NOT RETARDED..... no wait... whats the difference anyway??
Things are about the get very foggy in this Island...
I am going to Rons right now! (auto parts store)
Mental One
Old Jul 26, 2003 | 11:32 PM
EaC95Z28's Avatar
ok guys dumb question but what is seafoam and where can i get it?? and what do you do to use it?? do you just take off the elbow and spray it in the throttle body while the engine is hot? running or off?? and giving it gass to blow it out?? and what is fogging???? im confused it sounds good to do because it cleans the engine and why would you spray stuff down your brake booster cable?? doesnt that just deal with brakes?? im sorry im dumb i just dont get it????
Old Jul 26, 2003 | 11:43 PM
Eac the brake booster line he refers to is conected to the Intake manifold.... The brakes use the intake manifold vacum to aid in the braking process... when you disconect that hose and car is runing you will get that wonderfull succion feeling.....errr (grin) I mean... you get vacum and if you let any liquid in the vacum it will get sucked (oh god yes) right into your Intake manifold and into your combustion chambers... it will defenetely get to the carbon if ya know what I mean.
SeaFoam comes in a metal can about the size of a brake cleaner spray can... I have never used it but I have heard a lot about it..
Whats fogging? well all that cloud of white smoke that will come out of your tail pipes... will defenetely fog whoever is behind you..... almost as smoking a mustang kinda thing.. grin
Marvin
Old Jul 28, 2003 | 06:06 AM
Well, this is what I've done since day one. Seafoam can be found at NAPA and Carquest. First off, I've noticed on some Z28's that the engine will die when the brake booster line is removed. This can be fixed by unplugging the MAF which will cause the RPMs to shoot up a bit. I use a full can through the brake booster line every 10,000 miles or so.
Approximately 3/4 of the can should be poured into the line. Do this slowly as to not stall out the engine. Use the last 1/4 of the can to stall it out. With the RPMs this high it may be difficult to stall out the engine. Best bet would be to have a person in the driver's seat ready to shut the engine off. So.....make sure that the engine stalls out WITH seafoam in the cylinders.
Let the car sit for approximately 15-20 minutes. Plug the MAF and brake booster line back in. In the meantime, seafoam also makes a throttle body cleaner called Deep Creep. I use this 15-20 minutes to thoroughly clean out the TB. I open the blades up and brush the cars teeth (so to speak). Wipe it out real well with a towel, its not a big deal if some is left over in the TB. Hook everything back up and start the car. It will be difficult to start. Just keep cranking and work the gas pedal. Take it through the most crowded classy neighborhood you can find and fog the hell out of it. Make sure you get on it a bit. Don't stop driving until you blow it all out. You will notice a difference as soon as you start driving. Trust me.... This would also be a good time to replace the O2 sensors. Some people have said that seafoam fouls out the O2's which makes sense, but I've never had a problem I swear by the stuff. Every 10,000 miles since day one. 163,000 miles to date. Doesn't burn a drop of oil. Purrs like a kitten..... Good Luck!
Old Jul 29, 2003 | 05:04 PM
I finally DID IT!!! errr the Sea Foam I mean
I pulled the Brake boster line out then let it rest just on top of the booster conector... crank the car up... then used my finger to control the vacum on the vacum hose and slowly pur Sea Foam on it... I did it slowly untill the friggin car was smoking sooo much I almost choked!! /// fumes were coming out of the tail pipes and under the car... I turned her off and then waited about 10 minutes...
God Dayum!!!! I never made it to Kahala!!! I ended up foggin my own neighborhood until I was so embarassed I had to park her and turn her off... Cars behind me drove with the lights on cause could not see a dang thing...
so after I finally had oxygen back in my neighborhood I cranked her up to make a quick getaway from the area but Dang!! she didnt smoke anymore!!!
I did the remaining of the Sea Foam then but she just did not smoke anymore... I guess she got her pipes cleaned out (grin). and yes it does feel different... gets up to cruising speeds without any effort ... or so it feels..
Marvin
Old Aug 1, 2003 | 11:00 AM
Marvin
Awesome, I love seafoam. Its great stuff !
Old Aug 1, 2003 | 07:56 PM
BigRich's Avatar
Marvin,
sorry i didn't check back. I saw an ad for Daiei this week, SeaFoam and TransTune were just $4.99 ea
also, you gotta buy the Deep Creep in the spray can
that's like top end cleaner in a can. spray the **** out of your throttle body while someone steps on the gas.
see... i told you going to Kahala was better... bwahahahaa!
Nayr
Mar 3, 2023 08:34 PM
Jeff1904
Jun 5, 2016 05:00 PM
marlar98
Sep 19, 2015 07:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
blaze309
Sep 8, 2015 05:27 PM
