Confused by engine choices!
Ok. I am trying to plan out what I want to put into a '93-'97 TA and I am thoroughly confused by all the different choices out there.
I think I'm understanding now that a 383/396 doesn't have to be an LT1, but can be. There is just a regular SBC, but that is different from the LT1 block, right?
Now, why do some people not just use the LT1 block from their car and opt to build a new non-LT1 engine? What are the pros and cons of either?
That being said, can you please make some recommendations for me?
I want to build an engine that has a considerable amount of power, but doesn't have to be the fastest thing around. Maybe somewhere in the neighborhood of 450-500rwhp? It would be used for a daily driver. I'm also interested in a possible FI setup in the future (most likely SC) and would like to keep that in mind when building this engine. Does that usually work ok to build an engine for future FI, but not having one on for awhile?
Money is an issue of course, but I'm on no strict budget. I want to do things right and not skimp, but I also don't want to be excessive. There must be a happy medium, huh?!
Thanks so much!
Jeremy
Thanks so much!
Jeremy
Re: Confused by engine choices!
Thanks for the replies guys.
So are we talking a BIG sacrifice with the NA hp until the s/c is installed? Is it typically more expensive to build an engine to handle FI than it is to build a big hp NA engine?
In regards to cost, building a boost motor compared to an NA motor should be relatively the same. Differences being parts and machine work for desired CR.
97SS, thanks for the advice; I forgot that I had read that somewhere before too. What is the difference? Is it stronger? Did I read before that you could convert an LT1 to 4-bolt? Is that ok to do?
Camaroboy, that's good to hear. If I'm dropping all this money to rebuild the engine, I definately won't be able to talk the wife into a S/C right away! I'll have to wait a bit until the memory becomes foggy!
So, if I'm building an engine for a blower, what will I definately want to have as far as components are concerned?
EDIT: I suppose the blower could be included in that price as well but dont forget upgrading the fuel system too.
For internals you want lower compression pistons i'd say about a 9.0:1 ratio, make sure its all forged too, spend the ching on a forged crank if you can afford it, its worth its weight in GOLD,
With a setup like that, and keeping your fingers crossed your running some good heavy heads that wont lift you should be able to run 12-15 PSI out of that blower on there, can we say TIRE SMOKE?
Thank you both! This is exactly the type of information I was hoping to receive.
My goodness... I get all excited inside just thinking about it all!
I'll definately give the people at Combo and Bauer a call.
Typically, how much $$$ do you suppose one would save by assembling some of the engine themselves? Is it worth it?
Jeremy
Jeremy
Originally posted by 97SS_1341
If you plan on going wild like stroker and SC with high boost run a LT4 block or sometyhing with a 4 bolt main not an LT1
A 4-bolt Corvette block was used for the world's quickest LT1 - 1,125HP 383 Vortech S/C. Others have successfully done a "splayed 4-bolt conversion" on the 2-bolt block.
Injuneer,
So then is it best to use the 2 bolt, 4 bolt, or splayed 4-bolt? Is the last one reliable?
Injuneer,
To your other question, you'd save about $1000 or a little more by assembling it yourself. Leave it to the pros. Not to say it cant be done, but for the money you save I dont think its worth taking a chance.
95chwagon
Jan 13, 2015 09:19 PM
jrp4uc
17
Aug 8, 2002 07:31 AM
