Computer tuning
Old May 7, 2004 | 06:55 PM
lookingformore's Avatar
Computer tuning
Well.......i have to get a new program for my car...got the engine re-built. cam upgrade heads and stall and gears in rear....etc....Who should i send it to...i never looked into this before....I see PCM4less, I've already taked we guys at LSIspeed, and also Ed Wright.......any preferences out there......
Old May 7, 2004 | 07:43 PM
GreenDemon's Avatar
PCM for less is good...
Don't forget madz28
Those seem to be the top ones on this board.
Have you tried doing your own tuning?
The crazier your car gets the harder it will be to tune it through the mail- a good day dyno tuning with your own stuff could net some interesting results...
Old May 8, 2004 | 09:17 AM
How
How would i go about tuning this myself........????lap top and a program?????what program if so.......i don't know where to start.....
Old May 8, 2004 | 09:26 AM
jkipp84's Avatar
Re: How
I'd go with a mail order tune first. You just put a lot of time and $ into that engine - now's not the time to start your DIY pcm tuning. Once you've got a tune from one of them, you can compare it to the stock tune, do lots of research and testing, figure things out as you go.
Popular software for this would be Tunercat and LT1Edit. A Google search will help you on those. You'll also need a custom cable to interface your computer with the diagnostic port. AKM electronics has them, there's another one out there too, I can't remember the name off the top of my head though.
If you haven't already, check out the Computer Diagnostics/Programming board on this site too,
Old May 8, 2004 | 09:53 AM
Re: How
You might want to include info about your car in a "signature" -year, trans, major mods..... for this question, the year of the car is important, since it determines which software you need for tuning, and how much it costs.
Old May 8, 2004 | 11:00 AM
96capricemgr's Avatar
PCMforless is in PA and gets over to your side of the Delaware regularly so it would be possible to have him do it in person. I think all the options listed are good, just thought this might help make the desision.
Old May 10, 2004 | 03:39 PM
ok
I hae a 95 Z28 undergoing a engine re-build....cc305 cam...AFR heads.......stock bottom end with forged pistons.....the ususal bolt ons....FLP LT headers.....upgrade in Torque convertor 3000......could i still purchase my own software and be safe in tuning this myself......or is this best left to the professionals...don't want to hurt everything i just spent money on to fix........
Old May 10, 2004 | 04:01 PM
GreenDemon's Avatar
The best way to do it is to first get a tune from the pros. If you can get a dyno tune that's the way to go, but if you want to get into tuning yourself, get a tune for all your stuff from pcm4less and then compare it to stock to see what all they changed. Then go do some dyno tuning yourself and look at a/f ratios and look for knock retard or possibly advance the timing a degree or two to see if there's any potential left.
MadMav
May 25, 2015 09:35 PM
Jazsun
Dec 29, 2014 12:14 PM
dreamer1q
Sep 8, 2002 08:48 AM
