Low Coolant Light
Old May 10, 2004 | 04:06 PM
99BlackTA's Avatar
Question Low Coolant Light
My low coolant light turned on today and I went and got some 50/50 antifreeze and filled her all the way up. I drove the car around for a while and the light still won't turn off. Do I need to reset the computer or what else could be wrong?
Old May 10, 2004 | 04:08 PM
Red96Lt1's Avatar
If you filled up the reservoir, it might take a little while to get in to the radiator. The sensor is near the lower radiator hose.
Old May 10, 2004 | 04:11 PM
99BlackTA's Avatar
Thumbs up
Ok that's what I was thinking but I wasn't sure. Thanks for the help!
Old May 10, 2004 | 04:19 PM
BadBirdLT1's Avatar
the coolant sensor is very prone to failure it gets corroded and stops working causing the light to stay on. Unplug the sensor and pull it out clean it with some sos pads or oven cleaner just make sure it is thoroughly flushed of all cleaners. That might make it work again just o you know you will loose a decent amount of coolant when you pull the sensor.
calaban
May 18, 2020 06:43 PM
silvermansteve
Mar 4, 2015 05:02 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
