Computer throwing EGR circuit code
Old Mar 1, 2003 | 07:45 AM
wicked_95z's Avatar
Ever since I put my stroker in my computer has been throwing an EGR circuit code. I replaced the solenoid for the EGR and the valve is fine. I even took it off and cleaned all the carbon off of it. What else could be causing this?
Old Mar 1, 2003 | 10:57 AM
Which code?
If its the one for the EGR solenoid, you need to check the wiring... perhaps you pinched or damaged it when you did the engine work. You should have +12V on the brown wire whenever the key is on. You should not have anything on the gray wire when checking it at idle, since the PCM grounds that wire to complete the circuit when the EGR solenoid is activated, and it isn't activated at idle. If you have +12V at the brown wire, you need to do a continuity test on the gray wire.
Old Mar 1, 2003 | 11:13 AM
wicked_95z's Avatar
I want to say it was a P037 or something like that. Does that sound familiar? The scan tool said it was an EGR circuit. It didnt display any specific item of the circuit.
captcorvette
Mar 7, 2015 12:37 PM
cmdeshon
Jan 4, 2015 11:15 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Jazsun
Dec 29, 2014 12:14 PM
