Compressor goes on and off
Old Jul 9, 2006 | 03:43 PM
dubbsix's Avatar
Hey all,
I tried to recharge my AC system today and i noticed that the compressor cycled on and off and then finally i didnt hear it cycle anymore. Does this mean its bad?
I also tok out the pcm bat fuse and hoped it would revive the compressor but it didnt.
Old Jul 9, 2006 | 04:08 PM
predator's Avatar
Re: Compressor goes on and off
if it has too much pressure or not enough that will happen your pressure control swith could be bad also
Old Jul 9, 2006 | 04:10 PM
dubbsix's Avatar
Where is the pressure control switch located?
I also noticed that freon was leaking out of the low side fitting... Not sure why that would happen though. Can the low side fitting go bad? If so, then can i replace that fitting?
Old Jul 9, 2006 | 04:14 PM
predator's Avatar
i think the low side you have to replace the hose unless the valve stem in there is all thats bad the pressure control should be on the high side line it will have an electrical connector going to it you can jump the connector to see if the comp will come on but dont leave it like that i would have to look at my 94 to remember how it goes
Old Jul 9, 2006 | 04:17 PM
dubbsix's Avatar
I bought a kit from walmart and it came with a gauge. According to the guage i didnt over fill it, but i did notice that i had freon leaking from the valve.. I suspected i might have to replace the entire line.
Old Jul 9, 2006 | 05:05 PM
dubbsix's Avatar
I think the valve stem is bad.
2QUIK6
Sep 17, 2016 02:31 PM
Devinfoote87
Feb 12, 2016 03:21 PM
War Engine
Sep 18, 2015 07:28 PM
WPHIG2
Aug 27, 2015 06:37 AM
AtlasXVIII
Aug 24, 2015 11:41 PM
